Need help puting tranny back together.
Old Sep 11, 2001 | 04:58 PM
schrammer's Avatar
Car: "'86 Camaro
Engine: Two 1/2 Squirrels
Transmission: Shimano
Ok. I got my tranny apart, now I need help puting it back together. The tail housing won't make it all the way to bolt to the main case. I can't see anything binding, what could it be?
Old Sep 11, 2001 | 05:47 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Did you take the speedometer drive gear out of the tailshaft housing?
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. 2-1/2" cat-back, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 CC system w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker 2055 headers, 3" Catco cat & 3" catback, restalled TC, Spohn SFCs).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Old Sep 11, 2001 | 08:39 PM
schrammer's Avatar
Car: "'86 Camaro
Yes I did, should I put it back in? It would seem to me it should be easier to put it back together with it removed. It sure seems hard to get alot of help here, not many people answer my threads. Although that would be understandable today.
Old Sep 12, 2001 | 01:28 PM
five7kid's Avatar
I was thinking if you didn't, it wouldn't go back on. Since you did, I'm now over my head.
Perhaps transfixleo or Probuilt will respond.
Old Sep 12, 2001 | 03:19 PM
Pro Built Automatics's Avatar
If you see nothing in the way, and there are no dents in the seal area and the speedometer gear is not installed in the extension housing, then try tightening each of the bolts a half a turn at a time to see if you can draw it in evenly. It should be ok, do not forget the O-ring seal.
Old Sep 12, 2001 | 06:46 PM
schrammer's Avatar
Car: "'86 Camaro
I've tried that, it was really scary. it sounded like someting was grinding, or squealing, like two metal parts compresing against each other. And when I got it to within 1/2 inch, niether the input or output shafts would move. Theres gotta be something wrong inside.
Old Sep 13, 2001 | 04:50 PM
hotpowerandperf's Avatar
Sound to me like one of the clutches was not all the way engaged when you put it back together. This would cause the output shaft to be misaligned. My suggestion is to inspect the output shaft to make sure that it is in the center of the tail shaft when the tailshaft is square. If you find that the output shaft is misaligned then tear it back down and inspect the 3-4 clutches for evidence of damage from not being fully engaged. No matter what the problem is if the shafts bind up as it is assembled the transmission must be torn down to find what was not assembled correctly. Also do not try to force the tailshaft down using the bolts. It should go all the way down with minimal pressure. Tightening the tailshaft bolts with the output shaft misaligned may break the input drum the forward ring gear or both.
John
Heart of Texas Power and Performance
[This message has been edited by hotpowerandperf (edited September 13, 2001).]
Fronzizzle
Mar 18, 2019 08:29 PM
camaro11j
Sep 19, 2018 08:49 AM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
backtothe80s
Sep 5, 2015 12:39 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
