torque converter lockup
Old Jun 3, 2009 | 09:47 AM
Floorman279's Avatar
what is lockup?
Old Jun 3, 2009 | 11:49 AM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Re: torque converter lockup
There's a clutch inside the converter that eliminates any slip from the converter. You probably notice a 5th speed on your 4 speed transmission, this is the lockup.
Old Jun 4, 2009 | 12:32 PM
geehumshriber's Avatar
From Wikipedia:
Pumping losses within the torque converter reduce efficiency and generate waste heat (referring to how the motor is driven by transmission fluid). In modern automotive applications, this problem is commonly avoided by use of a lock-up clutch that physically links the pump and turbine, effectively changing the converter into a purely mechanical coupling. The result is no slippage (in an automatic transmission being fluid driven, there is pretty much always a small amount of slippage until the pump and turbine lock), and virtually no power loss.
Old Jun 4, 2009 | 03:22 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Lockup was introduced for reasons of MPG and emissions. Thus it unlocks under higher loads than those encounteres when cruising along at 80 mph. If you want a converter that can withstand locking under load, Yank and others can build them, but you'll need a fully-electronically-controlled automatic to utilize such a converter.
seiplentz
Aug 19, 2019 06:02 PM
customblackbird
Oct 1, 2015 04:30 PM
88rscamar0
Sep 23, 2015 09:08 PM
Nick McCardle
Sep 10, 2015 08:36 PM
