New Transmission and Converter: What Fluids?
Old Jun 3, 2009 | 06:55 PM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
Guys, need a quick answer. GOing to the shop tomorrow to drop of all the parts.
For a brand new torque converter and a brand new transmission, what fluids should I get? Don't you have to use a certain type of oil to break in a tranny and converter the same way you do an engine?
Old Jun 3, 2009 | 07:02 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: New Transmission and Converter: What Fluids?
Fill it with Dexron III. You can use any kind of compatible synthetic if you want. It's just a hydraulic oil. There's no such thing as break in oil for a transmission. Just make sure there's enough oil in the tranny before you fire up the engine. The fluid will drop as the converter and cooler lines fill. Fill it to the cold mark with the engine running. Drive around the block a few times to heat up the oil. The level should be on the hot full mark when the oil is warm.
Pour about 1/2 quart/liter into the converter before putting it on.
Old Jun 3, 2009 | 07:18 PM
Car: 1985 Z28
What is ATF?
I remember reading that a new converter needs it.
Old Jun 4, 2009 | 12:24 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
I thought Dexron VI is the best fluid out there now? GM even recommends it for the older automatics. I just had all the the Dexron III flushed out of my van and replaced with Dexron VI at the Chevy dealership.
Old Jun 4, 2009 | 12:26 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Originally Posted by FireDemonSiC
What is ATF?
automatic transmission fluid
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
Numbah-1
Sep 12, 2015 08:57 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
