Formula with drum rear?
Old Jun 3, 2009 | 11:52 PM
$750 L98's Avatar
Car: 1989 Formula 350 LSX
Engine: 5.3, 234/228 cam
Transmission: Stage II 4L60e, Vigilante 3200
I am under the impression formulas did not come with drum rear ends.
For some odd reason mine has one, it is a 1989 firebird formula, verified by vin. Did these cars come with drum rears, or disc only - which i believe is correct? If this is supposed to be a disc rear car, it would explain the bit of nose dive I have under hard braking. If some one has indeed done a cheap rear swap (probably because it had 3.73s) would it be fairly straight forward to swap back?
I have a perfect 1988 BW 9 bolt with 3.27 that I have all the hardware to, though i suspect the disc hardware (e-brake cables, etc.) were used on the drum rear i have now. Thanks for the help!
Old Jun 4, 2009 | 12:11 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Formula with drum rear?
Check your RPO codes
Old Jun 4, 2009 | 06:58 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The swap would be straightforward. You'd need a disc brake proportioning valve, the correct e-brake cables (disc brake cables wouldn't fit a drum rear), and drive and/or driven gears to make the speedo read correctly.
JamesC
Old Jun 5, 2009 | 10:15 AM
$750 L98's Avatar
RPO sheet is long gone, It is listed as a L98 car on the little sheet i found under the dash pad though, with all electric options, etc. It is also listed as a firebird FFM (firebird formula) on the title.
Does anyone know if the L98 cars were infact 4 wheel disc only?
Old Jun 5, 2009 | 11:06 AM
JamesC's Avatar
The following link is interesting, if nothing else:
https://www.thirdgen.org/forums/hist...-350-drum.html
JamesC
Old Jun 5, 2009 | 03:13 PM
$750 L98's Avatar
Sounds like some one must have swapped the rear out then, will start looking for a disc rear to replace it.
Orr89RocZ
Apr 25, 2016 08:28 AM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
Warlocksirix
Sep 3, 2015 12:26 PM
3rdgenparts
Aug 6, 2015 09:03 AM
