Convertor Staying Locked??
Old Sep 15, 2001 | 10:05 PM
88 IROC BOB's Avatar
I just recently swapped in my stock convertor and I get a vibration at low speed off the line and it really bogs until the rpm's get up.
It seems the convertor is staying locked--it idles really bad now and when at crusing rpm I have touched the brakes and rev's don't jump up.
Does this sound like the convertor staying locked up?
Bob
350 TPI, 700R4(rebuilt), K&N's, MSD 6AL, Headers, Flowmaster, 160* stat, airfoil, MAF screens cut out. 13.88 @ 101.18 mph
Old Sep 16, 2001 | 04:48 AM
transfixleo's Avatar
L/U won't occur, even with a malfunctioning solenoid, until you are in 2nd gear. That is the source of oil for the solenoid which in turn controls the L/U valve in the pump.
Old Sep 16, 2001 | 08:08 AM
Any ideas what the problem could be?
Bob
Old Sep 17, 2001 | 02:48 AM
Just for grins, unbolt the converter and push it all the way back into the pump. Now start the car and see if it still idles rough. If it does then it is some sort of engine problem, perhaps a vacuum leak. If it is a leak then you may not even be locking up and that would explain why it doesn't release with the brake.
[This message has been edited by transfixleo (edited September 17, 2001).]
bbsr72
Apr 2, 2016 09:12 AM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
Nervous2
Oct 8, 2015 10:53 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
