speedo gears
Old Jun 6, 2009 | 04:08 PM
ffemtm70's Avatar
Car: primered 1987 IROC-Z/28
Engine: 305 TPI HO
Axle/Gears: Lotsa slip 3.23
speedo gears
I just got a t5 and need to find the speedo gears and the adapter to go from electronic to mechanical speedo. If i did the math correctly I need a 7 and a 17 gear to make my speedo correct. I have a 3.23 rear and I am running 18 inch C5 rims on the rear. I have done searches on here as well as the rest of the web and I can't seem to find all these in one place......Any suggestions?
Also an adapter for the reverse lights and the neutral safety...I had a 700r4
Old Jun 7, 2009 | 06:53 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: speedo gears
The guys at the following site may be able to help:
http://www.transmissioncenter.net/sp...n_______va.htm
JamesC
Old Jun 7, 2009 | 11:57 AM
1986iroc350's Avatar
Car: 1986 Iroc z
Engine: 350 tpi
Re: speedo gears
Just bought mine on ebay. I only needed the driven gear of 45 teeth though. It cost me 8.00 plus 3.00 shipping.
Old Jun 7, 2009 | 01:01 PM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Re: speedo gears
I checked out that Transmission center site... I have no clue which one i need! I have a stock 700r4 with a eaton posi 3.73 motive gears in the back... When I'm going 50km/hour on my speedo, in reality i'm going about 60km/hour.
Which driven gear do I need to get?! And the last time I used a plastic one it snapped in half in 5 minutes... Are aluminum ones better??
Thanks!
-Marc
Old Jun 7, 2009 | 01:08 PM
JamesC's Avatar
Re: speedo gears
I'd phone.
86, who was the e-bay vendor?
JamesC
Old Jun 7, 2009 | 08:51 PM
Car: 1986 Iroc z
Engine: 350 tpi
Re: speedo gears
Originally Posted by JamesC
I'd phone.
JamesC
pm sent
Old Jun 7, 2009 | 08:58 PM
Car: 1986 Iroc z
Engine: 350 tpi
Re: speedo gears
Thanks!
-Marc
Heres another site to look on. It also has a speedo calculator you input tire size and rear end gear and it calculates what gears you need for the speedo. Mine was a 15 tooth and a 45 tooth. for the same setup that you have. http://www.bowtieoverdrives.com/index.shtml
GTAman
Jul 3, 2024 07:29 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
88rscamar0
Sep 23, 2015 09:08 PM
andy74
Sep 3, 2015 08:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
