LT1 and LT4 PP
Old Sep 20, 2001 | 11:29 AM
ScreaminDeamin85Z's Avatar
LT1 and LT4 PP
whats the diff between the 2? the guy at the Chevrolet dealership said that they didnt put LT4's in camaro's only in vettes but i know that they had a few with LT4's. i will be runnng a McLeod clutch with the engine combo in my sig, minus the heads.
Brandon
"ScreaminDeamin 360"
350 60 over, TRW forged 9.83:1 pistons,Hooker Comp headers, crane cam 216/228 .484/.512, crane 1.6 RR's, ported plenum, home made ram air, 24lb SVO injectors, crane AFPR, all going through 3 inch mandrel pipe and a flowmaster.
New project-89 IROC-305 5spd...Jamex Springs...and thats just about it!Soon- 6 speed, Pro 5.0 shifter and 4.10's
http://users.argolink.net/bvana
http://ScreaminDeamin.cz28.com
Old Sep 20, 2001 | 02:45 PM
poncho9789's Avatar
You are right the guy at the dealership is wrong. They did have some cammaros with the lt4s. The differences in the engines are:
Heads and intake ports are .100" larger than the lt1.
The cam is a little larger than the lt1 cam there are many people that think the lt4 cam is the lt4 hot cam, they are totally different.
Roller rockers 1.6:1
The lt4 has no egr system.
The lt4 also comes with a heavy duty timing chain.
97 formula w/6speed,cags skipshift eleminator, hurst billet pro shifter, 30#injectors,adjustiable fuel presure regulator,Moroso cold air induction,ported mass air sensor,accell300+ ignition box, accell 9000 wires, bosch platnum4 plugs,flomaster crossflow muffler,Lingenfiter 52mm throttle body,TPIS L98 SuperProfile cam,Crane 1:6 full roller rockers,Edelbrock subframe connectors,Edelbrock strut tower brace.
Other car is a 89 GTA w/700r4w/stage 2 shift kit,2800 converter, corvette servo, B&M mega shifter, TPIS bigmouth intake, TPIS large tube runners, TPIS 52mm throttle body,Edelbrock ported centerbolt heads,LT1 24# injectors,holly afpr,GMPP LT4 hotcam,CompCams Pro magnum roller rockers,Edelbrock headers, flowmaster crossflow muffler,MSD 6A, accell coil,150 shot NO2. This car is currently under rebuild and restoration.
88SS6SPEED
Nov 11, 2015 07:05 AM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
CatmanFS
Sep 19, 2015 09:00 AM
L0tuS
Sep 4, 2015 11:16 PM
