Need T5 VSS part # please
Old Sep 4, 2001 | 04:07 PM
Jed's Avatar
Jed
Car: 89 Formula 350
Engine: 360 / HSR
Hi all,
I'm just about done installing the aftermarket T56 in my car, which was an automatic. The T56 uses a T5 vehicle speed sensor, and I'm having a hard time finding one. The hole for the sending unit is about 1" in diameter - you can see it here (A).
http://www.sallee-chevrolet.com/images/bwt5610.gif
All of the parts places around here have a vss that is 2" in diameter, none have the smaller one. My GM parts catalog lists 3 different numbers, and I do not know which is correct.
Can somebody please tell me which vss I need, and provide me with a part number?
Thanks!
Jed
89 Formula 350
Old Sep 5, 2001 | 04:19 PM
Jed's Avatar
Jed
Car: 89 Formula 350
Engine: 360 / HSR
TTT
Old Sep 6, 2001 | 11:45 PM
Jed's Avatar
Jed
Car: 89 Formula 350
Engine: 360 / HSR
come on guys, please help me out! Someone has to know...
Old Sep 9, 2001 | 02:26 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Just go to the auto wreckers and pull one off a V6 or V8 Firebird, there both the same just make sure the car is 89 and down because i think the newer ones are different.
89 T-Top GTA 350 5-speed (soon to be 6-speed)
(Jet hot coated)1 3/4 SLP headers,flowmaster force 2,no cat's,SLP cold air,MSD 6al,march pulleys,ported plenum,air foil,B&M ripper shifter,180 stat,alston SFC,spohn LCA relocation brackets,free mods.
0-60 5.2s
Track Time
E.T. 14.14@96.7MPH (2300 FT)
Old Sep 9, 2001 | 06:01 PM
86Chicken's Avatar
Also you could just go to an Autozone or other friendly parts dealer and talk them into ordering all of the VSS part nos and you buy the one that you need.. That is what I did during my tranny swap.
Dale
1986 FireBird
2.8L MPFI
1/2 CAI
Gutted Cat, No muffler
Was 700-R4 --> Now T5
Great cars aren't bought, they are built
Old Sep 10, 2001 | 01:59 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Since when does a T56 use a T5 speedo sensor?
http://www.sallee-chevrolet.com/BorgWarner/bwt56.html
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
Old Sep 10, 2001 | 06:04 PM
Jed's Avatar
Jed
Car: 89 Formula 350
Engine: 360 / HSR
The aftermarket T56 uses one. It is supposed to be easier to swap into a thirdgen, but I can't find the vss anywhere so I don't know how much easier it is. I ordered one from Autozone, hopefully it will fit. I can't believe none of the parts stores in my area stock a T5 vss!
Old Sep 11, 2001 | 08:16 PM
Crusader's Avatar
Car: 1988 Firebird Formula
Axle/Gears: 3.45
Would I be able to replace a mechanical speedo gear in a T5 with the VSS and have it work? Everywhere I go/ask says no... Except one but it was a speed shop that mentioned doing one with like a ~$110 adapter... The one in my automatic is big, while the mechanical deally in the T5 is small...
Jess
Old Sep 11, 2001 | 09:18 PM
Jed's Avatar
Jed
Car: 89 Formula 350
Engine: 360 / HSR
You ought to be able to do that. You'd just need the VSS and speedo gear for it.
I received the correct vss from autozone.com today:
Wells part # SU1013
GM part # 25007345
The hold down bracket for this vss is
GM part # 12479577
Just in case anyone else is ever looking for this info.
Old Sep 11, 2001 | 10:32 PM
Crusader's Avatar
Axle/Gears: 3.45
How much were they? And how big is the VSS? Should that be all I need is just the VSS/Bracket?
Jess
Old Sep 11, 2001 | 10:45 PM
Jed's Avatar
Jed
Car: 89 Formula 350
Engine: 360 / HSR
Jess, the VSS is about 1" in diameter. It should be the one you need if your unit has the smaller hole. It was $55 at Autozone. I bought the bracket from gmpartsdirect.com, but you should be able to order it from any dealer, it was really cheap. You could probably make one if you wanted to.
All I have to do now is go to the dealer and get a gear for the vss. I may end up using the dakota digital box to calibrate my speedometer later on.
Old Sep 21, 2001 | 09:03 PM
Crusader's Avatar
Axle/Gears: 3.45
Thanks for the part #! It works almost perfect, just reads a bit slow.
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
fonzie85
Aug 13, 2015 11:50 AM
1nastygta
Aug 8, 2015 07:38 PM
