throttle cable adjustment custom???
Old Jun 11, 2009 | 05:14 PM
lordmetalz28's Avatar
Car: 1987 Z28 with iroc-z Package no.3
Engine: 350TPI
Axle/Gears: 3.73 posi
i put a new throttle body on and when i finished i re adjusted the cable and it clicked and everything normal.. after driving it im finding the shifts are not as firm as i had them.. and there maybe a tiny tiny slip going into lock up.. and when i hammer down on here she down shifts and then upshifts real quick something dosent feel right.. my question is can i manually play with that adjustment to find my happy zone i once had there.. maybe instead of adjusting it to full throttle.. open the linkage till it clicks out then back off.. any insight would be helpfull
Old Jun 11, 2009 | 08:01 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: throttle cable adjustment custom???
Try adjusting it again with the proper technique. I've tried probably 20 times to adjust it manually and it never works as good as when you do the proper adjustment on it.
You're still TPI right? If you have a SuperRam, you'll need a special bracket designed for the SuperRam. The stock bracket won't work with the SuperRam.
Old Jun 11, 2009 | 08:03 PM
Engine: 350TPI
I have been adjusting it the proper way.. thats what im not happy with.. yes im still running the stock tpi all besides the t-body
Old Jun 11, 2009 | 11:24 PM
91 1LE's Avatar
Car: '91 1LE
Engine: 377 w/Stealthram
Axle/Gears: 3.42 Torsen
Did you compare the new TB to the old one? If the replacement TB doesn't use a GM linkage the travel (arc) of the TV cable could be wrong. It sounds like the new one has a shorter travel (mounting hole closer to the throttle shaft) and is not extending the TV cable all the way. What brand of TB did you get?
Old Jun 12, 2009 | 04:26 PM
Engine: 350TPI
I got a Summit throttle body.. it came with 3 interchangeable links.. i used the one made for my car.. so lets say it is a fraction off(because a few things where on this Throttle body.. What could i do.. could i Adjust the cable but not all the way out so it makes up for some length???
Old Jun 14, 2009 | 07:55 AM
BlueChevyZ's Avatar
Car: '84 Z 28 RIP, Red 87 Iroc
Engine: has 8 cylinders
Transmission: has a stick coming out of it
Axle/Gears: no more pegleg
Here are several different links for the cable adjustment, maybe you could play with the mounting bracket, elonggate the mounting holes?
I have several sites, and all pretty much say the same thing, just that each site may have different pics, and diagrams.
http://www.tciauto.com/Products/Inst...ble_adjust.htm
http://www.transmissioncenter.net/subject.htm
http://www.tvmadeez.com/article/index.php
http://www.outlawtransmissions.com/v...s/support.html
9192camaro
16
Feb 3, 2019 12:21 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
timonator
Aug 13, 2015 11:27 PM
fonzie85
Aug 13, 2015 11:50 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
