4thgen rear guys...ebrake question
Old Sep 23, 2001 | 10:03 PM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
OK guys, I finished the rear swap along time ago. I have newly turned rotors, clean calipers, new bolts and pads, guide bolts and boots, stuff like that. I was under the car and just remembered I forgot to install the cables to the e-brake cable equalizer thingy (?) above the driveshaft. I still have the cables running through the little guide loops that bolt onto the differential cover...they don't quite reach. Should I bypass these or should I adjust that cable equalizer out? I was told I could do this with 3rdgen brackets and I'd rather do that...so how did you guys run you ebrake cables? Mine's a '95 Z28 rear, Torsen posi, 3.42 gears, differential cover/girdle, and soon Moser axleshafts. Tubes have been welded (if that makes a difference). Thanks for your help...the tech article didn't quite explain that part in-depth...
Old Sep 25, 2001 | 11:26 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
I got my cables to work with the ear-style holders on the diff cover. I adjusted the bracket above the d/s back about an inch and bent the parts open where the old third gen cables ran and than pushed the fourth gen cables in the bigger openings. I than popped the ends of the cables onto the bracket and used a hammer and a punch to form the rear of the bracket around the thick outer sheath part of the fourth gen cables to hold them in place. My e-brake works great and it is adjusted pretty much perfect - 0 drag on the brakes with a little to spare.
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
redmaroz
Aug 16, 2015 11:40 PM
