t5 swap
Old Jun 13, 2009 | 08:34 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
t5 swap
Ok I have a t5 from a 84 thirdgen I am putting into my 91 gta 5.7
question is which flywheel should I get? I have three to choose from.
a matching 84 camaro.. 168tooth
or a 91 gta, both are 153 tooth and a tbi model is different from a tpi. is the balance different on the flywheels from a 305 and 350? a stock flexplate on this car is a 168 tooth, so if i get a 153 tooth flywheel I need to move my starter in? I forget, can you move stock starters closer in?
Old Jun 14, 2009 | 03:25 PM
Jeff91RS's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: World Class T-5
Axle/Gears: 3.27 9-Bolt LSD
Re: t5 swap
From my understanding the t5 bell housing cannot fit a 168 tooth flywheel.
When you order it tell them what car you have, assuming u have the original engine, because your 91 GTA has a 1 piece rear main seal where an 84 would have a two piece which is a completely different flywheel. The balancing is no different from a 305 to a 350.
Old Jun 14, 2009 | 05:19 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Re: t5 swap
ok thanks jeff, i thought about the rear main difference but pictures didnt clearly show a differenc, ill take your word.
an 84 stock flywheel had a 168 tooth listed as stock. strange? ill stick with a 153tooth, I work in an auto parts store so I have behind the counter access.
oh ya, since im going to a smaller flywheel, do I need a new starter or are they remountable closer to the new flywheel?
Old Jun 14, 2009 | 05:25 PM
Jeff91RS's Avatar
Car: 91 RS
Engine: 350 TBI
Re: t5 swap
I do not know if you can "move" the starter. You could try posting in what ever section five7kid is a mod of because he answered all my questions when I was doing the swap.
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
355sbcTPI
Aug 19, 2015 04:38 PM
