TH350 vs 700R4 vs 2004R
Old Sep 26, 2001 | 10:55 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
We're having a debate on the thirdgen email list about these transmissions. I've always thought the 700R4 was an updated TH350, while the 2004R was a tranny built from scratch. They're saying the 700R4 was brand new, and the 200 came from the TH350. Who's right?
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
Old Sep 27, 2001 | 12:06 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
The 2004R seems to have more in common with the 350 design.
Old Sep 27, 2001 | 04:01 AM
transfixleo's Avatar
The 700 is based on the 350 but has some radical differences. The 200-4R is based on the 200 and is in fact a 200 with an O/D section added in front of it. This means that theoretically you could make a six speed out of it!
Old Sep 27, 2001 | 08:22 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
There's already a way to make a six speed out of a 4L80E. Since the tranny is electronically controlled, someone has come up with a new valve body that gives the 2 extra gears using the OD. No reason why it couldn't be done with the 200R4
Old Sep 27, 2001 | 10:29 PM
Pony Killer's Avatar
Car: 1986 Z28
Engine: 355
Transmission: th400
If memory serves me right. The back set of planetaries are the same setup, but not interchangeble to a TH350, the front planetaries, the input drum, the sprag set and the od are the differences. The 700 uses the TV cable for all the shifting instead of just a kickdown cable like the 350.
The 700 is an evolution of the 350, but it has "timed"shifts, whereas a th 350 more or less "stacks" the shifts.
2004R is a metric trans from the 200 3spd. the only thing it really shares with the 700R is the lockup servo, and a similar torque converter.
It's always SOMETHING
Old Sep 28, 2001 | 01:07 AM
Nordbert's Avatar
I must agree with Transfixleo. The 700-r4
must have come from a TH350 because you can swap the low/reverse roller clutches, the
low/reverse pistons look identical except for the slot for the parking pawl, and the
tail housings will bolt onto each other.
The 200 and the 200-4r both have one-piece
housings and share parts in the rear half.
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
