What's a batwing weight for?
Car: 89 Formula 350
Engine: 5.7 TPI
I have a 89 Formula 350 with a 700R4 and I was wondering why is there a weight called a batwing on the flexplate? If a small block 350 is internaly balanced why is this weight needed and what would happen if I used a flexplate without it. I have had other formulas and I have noticed this weight on all of them so I know it is not used to balance the flexplate itself. Any info?
Transmission: 4L80E/4L80E
If you have a two-piece rear main crank to look at, you'll see it has an offset counterbalance weight built onto the back end. Since the one-piece rear main crank has a round end on it, the counterbalance has to be put on the flexplate. So, technically it is a combination of internal and external balance - the harmonic damper is not counterweighted like it is on 400 cranks, which are externally balanced on both the damper and flexplate/flywheel.
Without it, you'll have a nice case of the shakes.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. 2-1/2" cat-back, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 CC system w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker 2055 headers, 3" Catco cat & 3" catback, restalled TC, Spohn SFCs).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
[This message has been edited by five7kid (edited September 27, 2001).]
Car: 89 Formula 350
Engine: 5.7 TPI
Yes, now that makes sense. But would I get vibration at all RPMs? The reason why I guestioned on having a flexplate without it is; I just had my flexplate replaced by a trans. shop and now I have a vibration at 2000-2500 RPM. It does it in drive and in park and is not related to mph. So I thought maybe the trans shop installed a flexplate without the weight. I don't think they would have I guess all one peice rear main engines should have to use this type of flexplate. I guess I will have to check it out.
Car: 88 Firebird WS6
They had to use the right plate because the bolt pattern is different. They do make the external (383,400ci) flexplates for the 1piece main seal, maybe they put one of them on there?
Damon
Sep 26, 2015 04:29 PM
