clutch slave leaking
Old Sep 27, 2001 | 08:56 PM
schrammer's Avatar
Car: "'86 Camaro
Engine: Two 1/2 Squirrels
Transmission: Shimano
Hi all. I hope all you "real mechanic" types aren't getting too sick of me yet. First the good news. I got my tranny back together allright. I guess when I was first trying to get the top cover off I kind of pried the reverse/fifth linkage over and got it jammed. Now the bad news. It looks as if someone (previous owner) had been doing some work on this thing, the little bolt on the slave cylinder (where you bleed it) is broken off. Worse yet, when I took it off to get the tranny off the nuts that are attached to the case of the slave broke off too. When I put it back in place, and pushed the pedal, fluid pissed out from around the rubber boot. I guess my question is, do I have to replace the whole slave assembly? Or is there some way to salvage it? Any suggestions are welcome, feel free to e-mail me. Thanks
Old Sep 28, 2001 | 02:01 AM
schrammer's Avatar
Car: "'86 Camaro
Just gotta get my topic up front.
Old Sep 28, 2001 | 07:20 AM
sunbound's Avatar
Car: 1987 IROC-Z
what year is your car? push or pull style slave cylender?
i have a 3rd gen with a t-5, push style, and im thinking that you may have to return it... though i only rember 1 screw... and thats the alen bleeder.
hope this helps a little
jon
Old Sep 28, 2001 | 09:10 AM
clemsparks's Avatar
Car: 1983 Z28
Transmission: WCT5
I doubt the screw was broken because IIRC it's an allen bolt that's more like a setscrew (sunken into the plastic housing). I could be wrong on that though as it's been a while since I messed with mine.
It sounds like you're gonna need a new slave cylinder though. They're really not rebuildable to my knowledge.
Clem
Clem
SCCA TransAm Series Race Mechanic/CrewChief
1983 Z28 with LG4, 5 speed, and (unfortunately) T-tops
1983 Z28, NO T-tops, (unfortunately) Auto Transmission (hopefully not for long)
Old Sep 28, 2001 | 11:45 AM
83 Crossfire TA's Avatar
Well, they are rebuildable (they have a separate steel sleave inside, a piston with a seal, o-rings slealing the ends, a big spring and a retaining ring and spacers), but the parts are unavailable, it's a PITA to get everythign to fit inside, and would cost more then just getting a new one, which is what you should do...
Mark
'87 Formula 350
’83 Crossfire TA
'97 WS6 TA (for sale)
Old Sep 28, 2001 | 09:18 PM
Tom Keliher's Avatar
A new slave cylinder from Autozone is $59 and it is the exact factory GM part number as stock.
devilschariot
Feb 25, 2016 03:08 AM
Drone358
Dec 10, 2015 08:16 PM
armybyrd
Sep 15, 2015 06:06 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
