any trick to installing slave Cyl in bracket?
Old Sep 13, 2015 | 12:30 PM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
My slave cyl is connected in the car but I need to get it mounted in the bellhousing bracket with the 2 bolts. Seems like it needs to be compressed to be able to put the bolts through. Am I missing something?
Old Sep 13, 2015 | 01:59 PM
Re: any trick to installing slave Cyl in bracket?
Nope, that's how it goes... after all, pushing on the clutch extends it, so it has to start out its motion at the bottom of its travel. The slight spring tension is what makes it automatically adjust.
You can use a C-clamp or something to hold it in place if you're having trouble holding it in depressed with one hand, holding up the bracket with another, and starting bolts with your 3rd and 4th hands.
Old Sep 15, 2015 | 11:24 AM
danryanm's Avatar
Car: '86 Trans Amvanian Frankenbird
Engine: 350 4bbl
Transmission: T5 4.03/.76
These are required tools to have if you expect to get any serious work done.
Old Sep 15, 2015 | 06:06 PM
Well, YEAH... and a 5th to hold your beer.
toronto formula
Nov 10, 2015 06:17 AM
fasteddi
Sep 2, 2015 10:29 AM
red90IROCls1
Aug 25, 2015 06:56 AM
Hello, Michael
Aug 20, 2015 03:19 PM
Dialed_In
Aug 20, 2015 01:45 PM
