LOCK-UP OR NOT?
Old Sep 28, 2001 | 09:09 PM
Madog's Avatar
LOCK-UP OR NOT?
From a performance point of view, Would it be a good idea to install the B&M DOWNSHIFT KIT FOR W.O.T IN 4TH GEAR?
AND, A HURST LOCK-UP HARNESS? ( IT DELAYS THE OPERATION OF THE TORQUE CONVERTER AND ELIMINATES THE IN/OUT ENGAGEMENT )
THANKS
Madog
Old Sep 29, 2001 | 07:23 AM
transfixleo's Avatar
Instead get GM #8673948. As for the in and out of L/U I would start checking the things that affect the ECM's decision to activate or release it, including EGR operation.
Old Oct 2, 2001 | 01:21 AM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Transfixleo
Do you know how to fit the GM shift kit?? I have it and am looking for instructions.
Rob
Old Oct 2, 2001 | 03:40 AM
http://www.transonline.com/electroPu...0/vb_side1.jpg
Look for the 3-4 line up, that is where the new 3-4 Throttle Valve Assy. goes. You also get a new TV boost Valve as I recall.
http://www.transonline.com/electroPublisher/clientdirectories/ images/totalTech/700r4_4l60/pump_valves_lineup.jpg
Ignore the mods that are mentioned in this illustration. It is the easiest way to help if you can see the parts.
[This message has been edited by transfixleo (edited October 02, 2001).]
Nick McCardle
Sep 10, 2015 08:36 PM
Chris's 85z
Apr 25, 2003 06:51 PM
Lurch
Carburetors
Jun 11, 2002 08:27 AM
