700R4 ...OH *** !!!!!!!!1
Old Oct 1, 2001 | 09:12 PM
burnoutrpm's Avatar
ok here's the deal..on my 700r4 the t.v. cable seems to have no effect on how or when the tranny shifts. ok no.2 problem, i put 3.73's in my car inplace of 2.73's i swapped tou complete rears. at first when i put them in the tranny would shoft through the gears faster than hell,.but now it shifts like a special olympic hurdler...why? problem no.3.on the 2nd to 3rd shifts you can hear a very annoying rattlte(like a loose timing chain sound) coming from the tourque converter..does this mean the converter is bad????? problem 4. when i stall it up it wont even stall to 1,000 rpms?? before it would stall to like 1500 or 1600????why is the converter cuasing all theses problems? a guy at the tranny shop siad it sounds like i have to much line pressure.
thanks
89 firebird formula
360 10:1compression (350 .060 over)/fully balnced and blueprinted
comp cams xe262 cam
performer rpm intake/port matched to heads
#1405edlebrock 600
sportsman 2 heads 64cc 2.02/1.60 valves 200cc intake runner/cnc pocket ported
msd 6al/msd8.5 super condutor wires
h.e.i. proform 50,000 volt vac. advance ditributor
700r-4 with 3.08 first gear and 3.23 posi 7 5/8 rear end.
b trans shift kit(will kill shifts...suck dong!!)
shorty heddman hedders with custom 3" pipe y-pipe back(no damn cat!) with 40 series flowmaster!
griffin daul1" core rad.cutom fabrication to fit(but no cutting )
future mods: 406 roller REALLY REALLY REALLY RADICAL!!!!!.with lots of NOS
Old Oct 2, 2001 | 03:47 AM
transfixleo's Avatar
My hunch is that the Throttle Valve is sticking in the VB. Too bad you didn't install a True Shift Kit (TransGo).
The early shift is because with the rear gear change you needed to put in the Hi Rev governor.
Stall changing? If you are sure where the noise is comeing from then OK, the converter is likely gone.
Old Oct 2, 2001 | 05:11 AM
Pro Built Automatics's Avatar
If you have lost the stall speed (was 1,600 now 1,000 rpm) the overrun sprag in the torque converter is gone. Time for a rebuild in the torque converter at a minimum. Look for metal in the pan, check the condition of the fluid? Yes, I would install the Trans-Go Shift kit once you have solved the torque converter problem, this will help eliminate the stuck TV valve and other inherent problems that present themselves in the 700R4.
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
