b-w 9 bolt to a 10 bolt
i have a 88 gta with the 9 bolt rear end i want to put a new gear in it as well as switch the whol rear end to a 10 bolt because i hurd the 9 bolt wasnt as strong i was wondering if anyone has done it i hurd there is a company by the name of strange that make's a 10 bolt to go inplace of a 9 bolt no proulbem, dose anyone know where you can get a 10 bolt to put on my car where i wouldnt have a lot of proulbems,
has anyone taken a normal 10 bolt out of a different camaro or trans am and put it in, dose it go right in or do you have to fab. a lot of stuff
also i have dis barks should that be a proulbem. any help would be nice
c&b
c&b
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The 9 bolt is stronger than a 10 bolt but parts are harder to find and are more expensive.
A 10 bolt can be beefed up to take a lot of abuse. I'm still running a 10 bolt in my race car.
Swapping them is easy. All third gen f-body diffs are direct swaps regardless of if they are a 10 bolt, 9 bolt or the rare Dana 44. External mounts are all the same. There are slight differences in castings, axle sizes, gear ratios, disk or drum brakes etc over the years but they'll all fit. You can even install a diff from a fourth gen but it'll be 2 inches wider on each side so proper offset rims are required.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block (times are for the current engine)
Best ET on a time slip: 11.447 altitude corrected to 10.99
Best MPH on a time slip: 119.42 altitude corrected to 124.86
Altitude corrected rear wheel HP: 493
Best 60 foot: 1.586
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.586
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
<font face="Verdana, Arial" size="2">i have a 88 gta with the 9 bolt rear end i want to put a new gear in it as well as switch the whol rear end to a 10 bolt because i hurd the 9 bolt wasnt as strong</font>
Miles
88 427 Camaro
12.18 @ 113mph 1.75 60ft
Currently installing 3.73's into my 9 bolt (YES, it is a 9 bolt & YES they are 3.73's, not 3.70. I currently have 4.10 gear sets and new series 3 carriers in stock for 9 bolts
)www.koolmeister.com
Numbah-1
Sep 12, 2015 08:57 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
