V8 T5 Transmission to V6 Swap
Old Jun 17, 2009 | 11:09 PM
1989RSV6's Avatar
Hey guys, I found what looks to be a solid transmission from a 1984 V8 Camaro, its a T5, and I am curious to see how hard it would be to put it on my 1989 2.8 liter, which also has a T5. I know I have to use the V6 bell housing and input shaft, but the speedometer gear is a 7 tooth and identical to the one in my v6, but is there anything else I need to worry about? I do know that the gear ratios are quite different, would this be detrimental on my V6? Any help or advice would be really appreciated. I did a search on the ratios and it didn't seem to turn up anything? This is my first transmission swap so I'm trying to learn what I can and hopefully do it right .
Thanks for reading!
Old Jun 20, 2009 | 10:25 PM
MFaust89's Avatar
Car: 88 IROC-Z / 92 z28
Engine: LB9 / sbc of a station wagon
Transmission: 700R4 / t5.6
Axle/Gears: i have 2 now!!
Re: V8 T5 Transmission to V6 Swap
welcome to the board. my point of view is: 1984 T5 is a non world class and the T5 u have right now is a world class. do some reading and find out the difference. hope u get to a conclusion
Old Jul 1, 2009 | 03:10 AM
cprepared125's Avatar
Car: 85 Z28 scca C Prepared
Engine: 5.7 348 RWHP
Transmission: t5
Axle/Gears: dana 44 3.41
all you should have to do is buy a v8 clutch disc and use the v6 bellhousing. it should all match up with no need to tear into the tranny.
Zane Story
Oct 8, 2015 12:40 PM
fbodyfreakls1
Oct 6, 2015 06:34 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
roysatikas
Sep 22, 2015 08:15 PM
apie2546
Sep 20, 2015 01:03 PM
