Can this be done....
Old Oct 2, 2001 | 08:49 AM
BowtieFever's Avatar
My 2.73 rear is ready for an upgrade. I searched to find that 91-92 Maros and Birds with a V6 and a manual tranny......have a 3.42 drum rear. so would this be a direct swap? how much is involved in this project?
92 Camaro RS
305 TBI
T-Tops
DynoMax Cat-Back Exhaust
Gutted Cat
Hypertech Street Runner Chip
Custom K&N open element cold air intake
Custom Interior
Window Tint
JVC El-Kameleon Head Unit
Pyramid 6 x 9's
Jensen 5 1/4's
2- 10" Kenwood Tornado Subs
Pyramid 600 Watt Amp
Best ET: 15.976 @ 86.01 mph
reaction time: 0.479
60 ft: 2.269
Old Oct 2, 2001 | 10:00 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Direct swap. Don't forget to swap the speedo gears while you are at it.
90 RS Convertible
Owner: Top-Down Solutions
(626)369-0040
http://www.sc3gfb.org/members/lonsal.html
http://www.taskerinc.com/gs3/profiles/Lon_profile.htm
Old Oct 2, 2001 | 12:12 PM
Is 91-92 (Maros and Birds), the only years the 3.42 drum rear was standard with a manual V6. Also how do you change the speedo gear?
Old Oct 2, 2001 | 04:46 PM
Anyone???
Old Oct 4, 2001 | 06:31 PM
AUTOGON350's Avatar
Car: 93 S10 blazer
I think earlier years of firebirds and camaros had the 3.42 with the v6.
The 1990 transmissions or at least the autos have vehicle speed sensors in the tailshaft of the tranny so the computer needs to be informed of the rear end change to keep the spedo working correctly. If you know anyone with a chip burner it is relativly simple to do. If you dont know anyone that can reprogram the chip I know a guy that can do it for you.
1990 TA 350 TPI
SPORTSMAN II HEADS
COMP CAMS 224-230@.50
52MM THROTTLE BODY
24LB INJECTORS
Marc Brown
Sep 28, 2015 01:40 PM
88fastgta
Members Firebirds
Jun 28, 2012 12:23 PM
Vicious
Mar 9, 2012 06:16 PM
bigboi0615
Oct 20, 2011 01:41 PM
