who can service a 9 bolt?
i live in louisville, ky. the passengre side axle seal on my borg warner 9 bolt is busted. i pulled the axle out but it looks like you need a press to get the bearings off to get the seal. just wondering if anyone in the area serviced them or where i should take it? thanks
Re: who can service a 9 bolt?
I'm about 2 hours away from you in Central City. That's south west of Louisville. Take 65 to E'town and the WK Parkway to Central City. Any good shop should be able to do this. Be sure that they press the bearing off and don't use a torch to cut it off. The heat can damage the heat treated steel of the axle.
UltRoadWarrior9
Sep 2, 2015 08:24 PM
