VSS to cable driver tranny?
Old Jun 21, 2009 | 06:22 PM
my90bird's Avatar
Car: 1990 firebird formula
Engine: 5.0 tpi
Transmission: t-5
can a digital speedo with a VSS be adapted to a cable drive tranny?th 350?
Old Apr 9, 2010 | 11:28 AM
tater's Avatar
Car: Dad's 87 Bird (Org Owner)
Engine: Vortec 350 Crate Motor
Transmission: TH350
Axle/Gears: 3.42 Posi
Re: VSS to cable driver tranny?
Interested also.
Old Apr 9, 2010 | 01:37 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
I am using one of these on my TH350 setup with Auto Meter guages. My speedometer bounces around a little bit but I'm not sure if thats because of this sender or the guage. Either way though, the sender works good.
http://www.summitracing.com/parts/ATM-5291/
Edit: I forgot to mention that this sender is designed to work with Auto Meter guages and according to them will not work with factory guages.
Old Apr 10, 2010 | 08:43 AM
tater's Avatar
Transmission: TH350
You're right, it won't work with factory gauges because the pulse rate is wrong.
I am hoping someone will chime in with an "easier" solution. lol
Old Apr 10, 2010 | 09:41 AM
dellman83Z's Avatar
Car: 87 monte aerocoupe
Engine: 383 HSR w/ novi 2000
Transmission: Built 4l80e circle d converter
Axle/Gears: Currie 9" 3.89 gears
I use a dakota digital sgi5 converter box and this sender http://www.summitracing.com/parts/SUM-G2887-1/, you can get the converter box from summit also. It takes a bit to get the speedo calibrated right, but it works great.
GTAman
Jul 3, 2024 07:29 PM
my86bird
Oct 23, 2015 12:20 PM
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
