700r4 vacuum line
Old Oct 7, 2001 | 11:51 AM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
700r4 vacuum line
is there one and where is it
i cant seem to find anything like that on the drivers side tranny. where is it. could that cause poor shifting. cuz it shifts kinda hard. sometimes to the point where u get whiplash
Old Oct 7, 2001 | 02:13 PM
Liam92L98's Avatar
spartyon
No, there is no vacuum line on the th700r4. Sounds like your TV cable is not properly set.
The way I use to set mine is; locate your throttle cables, carb or tpi, one is obviously your engine throttle an the other bigger one is you Throttle Valve(TV) cable. On the TV cable there will be a plastic housing with a half round metal part visible. Push that metal part in, it maybe hard, and then push the forward part of the cable towards the rear of the car. Then you adjust your TV cable by pushing you throttle pedal all the way to the floor, this will feel much harder than normal. What you are doing is pulling the throttle out of the housing. That metal piece is spring loaded. Even after that I usually pulled it out a couple more notches because the cable brackets flex alot. Therefore the cable would not pull out enough. Take it for a test drive, normally the further out the cable is the softer the shift, and vise versa.
clear as mud eh?
Bill
1992 Camaro Z28 L98
1997 K2500HD 6.5TD L65
1998 Yamaha WR400F
1988 Yamaha FZ750
1985 Yamaha RZ500
1999 Ski-doo MXZ600
Old Oct 8, 2001 | 02:04 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
hey man mud isnt very clear.haha but i get your drift. thanx man will try.
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
TheTraut88
Sep 7, 2015 05:22 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
