Best tranny and rear to go with 406 SB...?
Car: 88 IROC-Z/00 GTP/05 VUE Redline
Engine: LB9 305/3800 SC/3.5 SOHC V-TEC
Transmission: A4/A4/A5
I'm planning on swapping a 406 Small block into my 87 IROC 350 auto sometime within the next year. What tranny/rear end combo should I go with for this motor? I'm planning on putting a built 406 in the car that's going to either run a 150 shot of NOS or eventually get an ATI procharger and run 9-12 psi of boost. The motor alone should be pushing between 400-500HP without a power adder. What would my best bet be with the tranny and rear? I have some ideas of my own but you guys always seem to have something different and alot of times better. Any and all info is appreciated..thanks
"Turn a 12 second dream into a 10 second reality"
406 SB coming soon..
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
For a rear end, I dont think the 9-bolt will handle that, so you'll want a 12-bolt or a 9".
For a trans, what do you want? You can get a 700R4 to live for a while behind that, but it'd probably still die. Then you'd have to go with a TH400.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
i'd go with the th400 and a 9 inch
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
ICON Motorsports
1st & 3rd
