Torque converter question
Old Oct 9, 2001 | 09:47 AM
89Iroc-ZL98's Avatar
Car: 1989 Chevrolet Camaro IROC-Z
Engine: 5.7L TPI
Transmission: WC T-5
Will a torque converter out of my 89 Camaro Iroc with a 350 TPI engine work in an 88 Blazer, full size, with a 350 TBI engine? Both have TH700R4 trannys.
Purpose for this question. I have lost lockup on my Blazers converter and there is a heavy vibration that worsens as RPM's increase. I am pretty sure I have it narrowed down to the torque converter (harmonic balancer is tight and accessories seem ok). I recently swapped a T-5 in place of my 700R in my Camaro so I have a spare torque converter with 47K on. Tranny on the Blazer (114K miles on truck) shifts fine for now, just the converter problem (I hope). I can't swing a rebuild right now and I don't want to put a new converter in front of a 114K tranny. Will the Camaros work? How compatable is the stall speed?
Any help is appreciated.
Old Oct 9, 2001 | 10:50 AM
82camaro's Avatar
Car: 82 camaro SC
Should work just fine.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
jklein337
Sep 19, 2018 06:23 PM
69 Six Pack
Oct 5, 2015 07:51 PM
redmaroz
Aug 16, 2015 11:40 PM
gwade12
Aug 8, 2015 08:17 AM
