gm rear end additive
Old Oct 9, 2001 | 10:18 AM
john72ss's Avatar
does it really work, with a limited slip rear?.... how much does it cost??........85 z28 just rebuilt but stating to whine a littl!
Old Oct 9, 2001 | 01:12 PM
CODY BEHNKE's Avatar
Usually a whine is because of gear misalignment,if it just started doing it i'd have it checked out. Make sure the pinion bearing and carrier bearings are good. Limited-Slip additives are usesd mostly to eliminate chatter in the diff. clutches.
Old Oct 9, 2001 | 01:23 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
What kind of ring and pinion did you use in your rebuild? Because most High Performance aftermarket gear sets are built with strength and longevity in mind and not quietness of operation........
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
Old Oct 10, 2001 | 08:42 AM
ede's Avatar
ede
the gm additive works very well, better than most aftermarket additives. it's a friction enhancer for the clutchs so they don't chatter. it cost me little over 5 dollars a bottle, cost you a little more.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
