91 Z28 Camaro rear end
Old Oct 9, 2001 | 08:54 AM
NOCANDO's Avatar
Will a 1991 Z28 Camaro rear end with disc brakes fit on a 92 Camaro RS.....Also what is the Z28's gear ratio...I think the 92 Camaro RS is 308...
Old Oct 9, 2001 | 01:16 PM
CODY BEHNKE's Avatar
It will but you have to upgrade the brake system on the RS to work with the disc rear end, or transfer the drums over. Z28's can have 2.73,3.42,3.27 it depends which engine it has and what tranny it had also.
Old Oct 9, 2001 | 01:25 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Yup. All you need to get the rear disc brakes working with your current setup is a master cylinder and a proportioning valve from a four wheel disc car to go with it. What about the master cyl. and prop. valve in the car that the rear axle came out of?
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
Old Oct 10, 2001 | 03:46 AM
NOCANDO's Avatar
Thanks for the info guys...
Old Oct 10, 2001 | 11:57 AM
Momar's Avatar
I was just wondering why you need the proportioning valve. Doesnt it just change the amount of braking power going to the front and rear. What will happen if you use the one from the drum brakes. Will it cause problems???
Old Oct 10, 2001 | 05:55 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
My dad put an 89 rear end into his 92 RS, he didnt have to change anything else.
The Z28 rear end could be 3.23 if it was from a 350 automatic, or 3.42 if it was from a 305 5-speed.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
hectre13
Dec 11, 2023 08:14 AM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
AkDrifted
Aug 17, 2015 07:45 PM
BlackBoulder
Aug 11, 2015 11:15 PM
novaderrik
Aug 10, 2015 12:44 PM
