Rear End Help
Old Oct 7, 2001 | 09:58 PM
90RSErik's Avatar
Rear End Help
I have a 90 Camaro RS w/ the TBI and the 2.73 gears. I wanna upgrade to 3.42 or 3.73 and also add posi. Someone offered to sell me the used ring and pinion gears out of their 95 Z28 (3.42). This is a 7.5" ring gear. My question is, can I use this? (basically, does my rearend take a 7.5" ring gear?) Plus, is that all that I would need to upgrade to the 3.42 rear end? What's a good price for just the gears? and also, what's a good posi unit, where do i get it, and what's a good price? Thanks
Old Oct 7, 2001 | 10:10 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
A brand new set of gears is about $200, so let that be your guide to what a used set is worth.
Cheapest/best way to come up with a posi for your situation would be the SLP takeoff for $99 bucks, or maybe even $79 if they're still swimming in them.
ICON Motorsports
Old Oct 10, 2001 | 08:33 PM
90RSErik's Avatar
What about my other question?
do i have 7.5" rear-end/ will a 7.5" ring gear work for me?
Old Oct 10, 2001 | 11:50 PM
MichaelRBrumm's Avatar
2.73 uses a "2-series" carrier (so does 3.08)
3.42 uses a "3-series" carrier
A 3.42 ring gear will not work on a 2.73 carrier.
Yes, 7.5 or 7.625 inch will work.
Gears can be found for $150 + shipping.
Since you need a carrier, do like RB83L69
says, and get a Zexel Torsen from SLP for $100. They are VERY GOOD limited slip differentials.
http://www.slponline.com/view_produc...TNUMBER=64501T
If you are going to do heavy dragging with slicks, then get their heavy duty version:
http://www.slponline.com/view_produc...RTNUMBER=65002
Finally, expect to pay someone to swap your gears and carrier. It isn't a do-it-yourself job and it can cost big bucks.
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
