Speedo gear and rear gear swap...
Old Oct 11, 2001 | 12:10 AM
mynyka's Avatar
I just had 3:73s installed in my 88 formula and I havent changed the speedo gears yet. Is this going to adversely affect performance or is my speedo just going to be off? I heard somewhere that it could affect how the engine runs and/or produces power but I think its B/S. Any info you might have would be greatly appreciated.
Drew
Old Oct 11, 2001 | 02:48 AM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
The only bad thing is the speedo being off and thus, when the TCC locks and a few other minor things. If your EEPROM has Highway Mode enabled in it, that will also be affected as it looks at speed for when to apply. No engine power related issues will result from this; only little things that use the VSS input for when to 'happen'.
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
Old Oct 11, 2001 | 03:56 AM
mynyka's Avatar
Hmm... maybe thats why my converter locks immediately when I shift into od. No matter how hard I'm on the gas it will lock no matter what as soon as I shift. then it shifts into od.
Drew
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
Jlanz55
Aug 17, 2015 07:15 AM
mizz0313
Aug 12, 2015 06:45 AM
