Too Late for Shift Kit?
Old Oct 5, 2001 | 11:40 AM
90RSErik's Avatar
In lurking on these boards, I've decided that the best way to go for my 1990 RS with the 700R4 is the Corvette servo and Trans-Go shift kit (I hope this doesn't turn into an "I hate B&M thread). The only thing that I'm worried about is that the trans has 114,000 miles on it. It has been well maintained, it shifts fine, and everything is solid on it (except the trans mount - new ES one on the way). But is it too late to put in the shift kit and/or vette servo? I've read that those upgrades are great on a relatively newer trans, by providing firmer shifts and hence less slippage, but then I've heard that on a higher mileage 700r4, it could actually cause slippage. I guess what it boils down to is that I would like to do these upgrades, and I want to know if it is feasible (note: the trans operates pretty well now with no signs of slippage.)
Old Oct 5, 2001 | 12:53 PM
82camaro's Avatar
Car: 82 camaro SC
If the tranny is shifting good and the fluid looks good, install the shift kit. It's only too late when the tranny shifts terrible and/or the fluid is burnt. Forget the mileage.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
Old Oct 5, 2001 | 02:03 PM
Pro Built Automatics's Avatar
Yes, the Performance Shift kit with both boost valves, and Corvette servo should work out fine. If you do not already have the parts, I can supply with all this & some tech info. Let me know?
Old Oct 10, 2001 | 08:31 PM
90RSErik's Avatar
Hey Pro-Built...
email me with info on a shift kit (preferably trans go)and the corvette servo.
estumph1@yahoo.com
also, isn't there something that will allow me to drive at WOT in overdrive?
any info would be appreciated like cost and tech help etc.
Old Oct 11, 2001 | 04:02 AM
mynyka's Avatar
what exactly does the corvette servo do?
Drew
Old Oct 11, 2001 | 09:31 AM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
The covette servo makes upshifts and downshifts more snappy in all gears.
Old Oct 11, 2001 | 06:56 PM
transfixleo's Avatar
The 'Vette servo is the largest factory Servo and provides more holding power in second at any given pressure. It also makes the 2-3 feel firmer because the Servo releases slower on the shift and you get more bind up. This is not necessarily a good thing. This is also why I don't use the aftermarket 'Super Servo' since it is even larger.
[This message has been edited by transfixleo (edited October 11, 2001).]
PestilenceIV
Sep 11, 2016 12:53 AM
TheTraut88
Sep 7, 2015 05:22 PM
dimented24x7
Sep 6, 2015 03:51 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
