what should I do!?
Old Oct 12, 2001 | 12:35 AM
Jer82Z28's Avatar
Car: 1987 IROC
Engine: Vortec 350 TPI
Transmission: 7004r
what should I do!?
ok right now I've got a 700r in my 82 camaro.
I want to put a TC in it, 2500-3000 stall but I don't expect the trans to last very long, so these are my thoughts.
Plan 1; get a cheap throw away converter and run it until the trans lets go and purchase a different transmission, like the 200-4R or a T56
Plan 2; get a quality converter for big $$$ and spend more $$ on trans rebuild and have a very reliable 700r for my possible nitrous runs. or puchase a built 700r when current one kwangs.
plan 3: forget about spending any money on the 700r and purchase a T56 and convert to manual.
does anyone have any thoughts on this?
the car will remain a street car, and (hopefully) get lots of track time in. i also plan some suspension work for max traction and eventually running AFR heads with nitrous.
Camaro nut in training.
1982 Camaro Z28
350/700r4
Vortec heads, comp cams XE262H, dynomax 1 1/2 headers, edelbrock 750 carb/performer rpm, MSD ignition, K&N,
3.73's with powertrax locker
best 1/4mile time
13.6@104*
1984 Camaro Z28
(parts)
1985 Camaro Z28
305/700r4
Accel ignition, K&N
*with crushed exhaust and badly tuned carb. corrected for elevation.
Old Oct 12, 2001 | 07:51 AM
ede's Avatar
ede
i'd go with a preformance built auto with a good quality converter. if you want to run low gears the od feature makes the 700r4 attractive. the manual trans will never give you good or consistant 60' times or ets.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
