Odd noise under acceleration
Old Jun 29, 2009 | 01:43 PM
big_cam1982's Avatar
Car: 1988 Camaro
Engine: 355 Carb'd
Axle/Gears: 9-Bolt GM 3.73
I have a carbed 355 with decent power, a t-56, and a 9-bolt. My crossmember and torque arm (Adjustable and spherical rod end) are spohn. I have an odd noise under really hard acceleration. It's not a whining noise, more of a rrr...rrr...rrr... that gets louder and louder as the car begins to accelerate more. I have no noise under normal (or what regular people call normal) driving conditions. Even on light or moderate acceleration there is nothing. Also when the tires are spinning during a burnout no noise until the car starts to hookup, then continues throughout WOT, shifting, then until I'm off the gas. I'm not too sure but maybe pinion angle? The car is lowered but not slammed, it has adj panhard. Any Help?
Old Jun 29, 2009 | 02:01 PM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Re: Odd noise under acceleration
Have you always had the noise, or is it something new? The rod-end TA will transmit tons of drivetrain noise to the driver. If I had to guess, I'd say your 9bolt can't handle the 355/T56 and has started some Death Throes.
Old Jun 29, 2009 | 02:43 PM
Car: 1988 Camaro
Engine: 355 Carb'd
Yeah I wish i hadn't went with the rod end, didn't really need to, would like to go back and get poly instead. I sure hope the 9bolt isn't failing, when I got it I had a local rodder/mechanic friend go through it and put the 3.73, said it looked pretty good then but...
Pac J
May 17, 2020 10:44 AM
RedLeader289
May 28, 2019 01:47 PM
Mark_ZZ3
May 24, 2018 01:02 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
sjorgens
Oct 1, 2015 07:54 PM
