Blown Clutch, or Cable, possibly???
Old Oct 14, 2001 | 01:17 PM
KZad's Avatar
Car: 88 Formula, 04 CTS-V, 06 Commander
Engine: 305 TBI, LS6, 4.7 V-8
Transmission: 5 spd, B&M Short Throw
Hey -
Yesterday, I was about to come up on the clutch to put my car into gear, and the car slammed into first, bogging like no other, so I ripped it outta gear (like any other time it would have bogged). When i went to drive it again, the clutch was just dangling like a broken arm. I got out of the car, and I was overwhelmed by the smell of burnt clutch. Any ideas?? I havnt had a chance to look at it yet, anything to look for??? Any guess at a price to fix, and which aftermarket clutch should I be looking for, performance or non. Thank you.
-KZad
1988 Firebird Formula 305 TBI, T-Tops, RED.
Of course ... 5-Speed
Old Oct 14, 2001 | 02:01 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Sounds like the "slave cylinder" broke off the mount. If you look up under the car, you will see a black cylinder that should be bolted to the bellhousing of the tranny. It may be broken. It will have a hose running up to the firewall. I beleive they are relatively inexpensive.
FREE CARFAX Record Check
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
Old Oct 14, 2001 | 02:03 PM
Camarodan's Avatar
I had a similar thing happen to me once. I went to shift to third gear when the clutch pedal just went to the floor with no pressure and just dangled there afterwards. The cause of it was that the clutch cable had laid on the header and burnt. Causing a small fire under the hood. If I remember correctly that part was about $100 and isn't that difficult to replace with some patience.
[This message has been edited by Camarodan (edited October 14, 2001).]
Old Oct 14, 2001 | 07:58 PM
MidnightZ's Avatar
The same thing happened to me last week. It turned out that the ball stud on my Z-bar snapped. My car doesn't have a hydraulic system though, so I'm not sure how those work.
Old Oct 14, 2001 | 08:14 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
A Z-bar? Wow, you must have an '82? I think thats the only year they still used Z-bars.
Old Oct 14, 2001 | 08:35 PM
87RS402's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Camarodan:
I had a similar thing happen to me once. ... The cause of it was that the clutch cable had laid on the header and burnt. ... If I remember correctly that part was about $100 and isn't that difficult to replace with some patience.
</font>
Had the exact same thing happen, cost less than $10 to fix. Brass compression fitting and brake fluid.
Old Oct 14, 2001 | 10:24 PM
MidnightZ's Avatar
I have an 83. They had the manual setup in 82 and 83, but the T5 came out in 83. So it is the only year with a T5 and manual linkage.
Drone358
Dec 10, 2015 08:16 PM
TheTraut88
Sep 11, 2015 05:16 AM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
