Pinion...
Old Oct 14, 2001 | 03:27 PM
Chad's Avatar
Pinion...
Problem, cant get the pinion out of the carrier. Got the nut off, but the u-joint is still there. Also, this coming out of a 10 bolt posi 3.42. I have a 10 bolt 2.73, I cant use the same pinion, can I? Thank you!
Old Oct 14, 2001 | 03:57 PM
Jay 727's Avatar
Re-use the same pinion? Thats not really a good question..How in the hell did you get the pinion nut off with the u joint still in place?! I think you might mean the pinion yolk? just use a hammer to tap it off if thats what you mean.
Old Oct 14, 2001 | 04:07 PM
Chad's Avatar
Sorry, yes, the yoke. I hammered and hammered, but the pinion wont go out. Am I missing something?
Old Oct 14, 2001 | 08:18 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Kent-Moore makes a special puller to pull it off, and when a few hammer taps won't knock it off, I use the puller, since hitting it too hard endangers the parts. But they can be very tough to get off, on the other hand, sometimes they come right off.
FREE CARFAX Record Check
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
Old Oct 14, 2001 | 10:03 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Get the yoke off first. Once that's off the pinion should come out with a few hits with the hammer.
Old Oct 15, 2001 | 02:53 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
<font face="Verdana, Arial" size="2">Kent-Moore makes a special puller to.... </font>
Maybe you get a good discount, but they wanted over $800 for their pinion depth setting gauge! Unreal! So I got a Precision Measurement Sys one instead for ~$125. Kent-Moore what a joke, quality stuff but bend over prices.
newZman
Mar 5, 2011 09:00 PM
jak2908
Jan 3, 2010 08:39 PM
Xandarin
Apr 16, 2008 11:43 PM
RU-QWIK
Feb 8, 2008 10:39 PM
