Swapping the rear end in my 84 Z28
Old Mar 4, 2011 | 05:10 PM
newZman's Avatar
Car: 99 Tahoe, 98 Buick, 84 Camaro
Engine: 350, 2800, none at the moment
Hello all,
I am going to swap a series II 10 bolt rearend into my car that has a series III 10 bolt rearend.
The reason I am doing this is because the car now has the standard diff with 3.73 gears/pinion (which is a good gear ratio) but, I would like a posi reaerend. I was able to get an 86 limited slip differential with new Richmond 3.42 ring/pinion gears, the matching installation kit for a series II carrier and the series II carrier with drums attached for $150, so I snatched it up. I got the original pinion gear and ring with it as well and is mostly disassembled.
How difficult is it to get the new rear end in the car so that it is straight, so the car doesn't look like it is going left or right when it is actually straight?
Does it line up pretty easily?
I also had a question regarding the backlash setting for the ring and pinion...
I am sort of confused after looking at the instructions posted by a fellow TGO member as to where to measure the play. Correct me if I am wrong but, It looks to me like if I set the diff in the carrier and bolt the hangers there wont be any play front to back with the diff... Right? This makes me think I would measure at the end of the pinion gears shaft. Am I way off here?
Where is the backlash measured and which direction is the play (i.e. front to back, side to side, up and down etc...)?
Thanks,
newZman
Old Mar 4, 2011 | 05:26 PM
newZman's Avatar
Re: Swapping the rear end in my 84 Z28
Here are some pics of the stuff I got;
If I get this right
The whole kit + diff and ring/pinion.
Attached Thumbnails Swapping the rear end in my 84 Z28-whole-kit.jpg   Swapping the rear end in my 84 Z28-ring-pinion.jpg   Swapping the rear end in my 84 Z28-lsp_diff.jpg
Old Mar 4, 2011 | 05:30 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Torque arm holds the rear position up/down (yoke relative to tranny, so the pinion angle is correct). Lower Control Arms hold the rear straight with the car. Panhard bar holds it centered left to right. Unless any of those are adjustable replacements on your car, there's only one way to put the rear end in, and that is straight.
Old Mar 4, 2011 | 05:49 PM
newZman's Avatar
Excellent that's what I wanted to hear. Hopefully I cant mess it up then.
Old Mar 4, 2011 | 05:55 PM
Car: 1992 RS
Engine: Carbed 350
Nope - can't really mess up the install of the rear end. Springs will fall out, use electrical tape to hold the rubbers on top of them when you replace them. Replace swaybar endlinks while under there as well.
I know nothing about the shimming of the internals, but there's posts here about it, try a search. Good Luck!
Old Mar 4, 2011 | 07:52 PM
big gear head's Avatar
https://www.thirdgen.org/forums/tran...axle-gear.html
Old Mar 5, 2011 | 09:00 PM
newZman's Avatar
Thanks big gear head, I'll be checking that out, from what I have read so far I like the quality on this instruction better. I may still have some questions.
newZman
hectre13
Dec 11, 2023 08:14 AM
IroczFan
Oct 6, 2015 10:13 AM
mizz0313
Aug 12, 2015 06:45 AM
novaderrik
Aug 10, 2015 12:44 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
