T-56 Noise
T-56 Noise
OK, some of you guys with a T-56 may be able to help me here. I have a 92 Firebird with a 97 T-56 transmission. The trans had 42k on it went I got it (I saw the car). When I installed it, I used the donor cars clutch cylinder and pressure plate. I used the original throwout bearing, but put a new stock clutch in it. A few weeks a ago, I though I heard a low "growl" when shifting into 3rd. That growl has become more often and happens going into 2nd also. I have also heard it in 4th now. You only get the noise when shifting and the car is moving. I can shift, with the car running, all day long and will never hear it.
Any ideas....
Mark
1992 Pontiac Firebird 350/Six Speed
1987 Toyota Pickup 383/500+ HP
Any ideas....
Mark
Car: 1991 Camaro Z28
Engine: Dart SHP 406ci T88 turbo
Axle/Gears: QP 35 spline Ford 9" 3.50 gears
If you hear the noise when the clutch is depressed then you probably need a new throwout bearing.
92' Camaro RS 305 TBI
Best 1/4 mile - 14.6 @ 96 mph w/NO NOS
Best 60' - 1.9 secs
Check it out
https://www.thirdgen.org/rides/index.tgo?action=view&rideid=4860
Best 60' - 1.9 secs
Check it out
tonys91rs
Oct 10, 2015 03:31 PM
sjorgens
Oct 1, 2015 07:54 PM
