Transmission Trivia---????
Old Jul 3, 2009 | 05:45 PM
armdale's Avatar
Car: 1984 Trans Am
Engine: 5.0 Litre H.O Modified
Transmission: 5 Speed Manual
Axle/Gears: 3.73 Limited Slip Posi-Trac
At what speed does a 1984 Trans Am with a 700 4-R Trans High speed down shift?
[ It keeps trying to shift from passing gear to overdrive and visa versa and wont go any faster]
Old Jul 6, 2009 | 02:04 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Transmission Trivia---????
what the heck are you trying to do, go 140? Start with readjusting the throttle valve cable.
Old Jul 6, 2009 | 02:08 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
by the way, you started with a trick question, because the answer depends on a number of variables, and the hunting you describe, if at part throttle, used to be a common complaint. If this issue is at WOT, then quit trying to go that fast. This is the USA, not the German Autobahn. But if this hunting is at WOT, you need B&M's WOT 4th gear valve, it's what, $30, or maybe $60?
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
TX-SleeperC5
Sep 24, 2015 03:13 PM
Youngs92
Sep 23, 2015 11:29 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
