what rearends were available for the GTA?
Car: 1987 IROC
Engine: Vortec 350 TPI
Transmission: 7004r
found a junked GTA at the autowreckers with rear disc brakes. Where can i find info on what rearends were put on the GTAs? were all of them posi? what thinks should i look for to find out if it's a posi, has the 3.27 gear?
thanks
thanks
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Look at the rear cover. If it has 9 bolts the it's a Borg Warner diff and there's a very good chance it's 3.27 gear and a posi if it's an auto or 3.42 gear if it's manual.
If there's 10 bolts then you'll have to pull the cover and look inside.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block (times are for the current engine)
Best ET on a time slip: 11.447 altitude corrected to 10.99
Best MPH on a time slip: 119.42 altitude corrected to 124.86
Altitude corrected rear wheel HP: 493
Best 60 foot: 1.586
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.586
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
What year is it from? It could be 2.77, 3.27, 3.23, 3.42, or 3.45. And yes, it will be posi.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
2012sergen11
Oct 13, 2015 07:38 PM
