transgo shift kit
Old Oct 23, 2001 | 08:30 PM
89formula350tpi's Avatar
Car: 1989 Firebird Formula
Engine: 350 tpi
transgo shift kit
I'm going to be putting in a transgo shift kit in my 700r4 and I also want to do a TCI manual valve body so I can shift manually. But the transgo shift kit says you can have full manual control. So is there a need for the manual valve body.
Old Oct 23, 2001 | 08:34 PM
Jay 727's Avatar
The last transgo kit I installed, the 2&3 reprogramming kit had an option to convert it to full manual so that should be all you need.
Old Oct 24, 2001 | 12:06 PM
Pro Built Automatics's Avatar
You cannot mix the two kits or valve bodies. If you want the best success use the Trans-Go only. Make sure you install the boost valves & (hi-rev spring kit if you have the trans out), & Corvette servo. I would go with the automatic setup, as you can still manually shift it at hi rpm's (override the governor), but have the automatic features when driving around town.
Old Oct 24, 2001 | 01:09 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
shiftin manual on an auto, how so? not much of a tranny guy here
86 berlinetta
350cui w/.30 over
.526 hilift cam
hooker supercomps
3" duals
edelbrock streetmaster
holley 750 dp
bad asshauler
Old Oct 24, 2001 | 01:21 PM
If the governor says to make the 1-2, 2-3, 3-4 WOT shift at 4,800 rpm and you want it to go to 5,500 rpm you can hold the lever in that gear to that 5,500 rpm or any rpm if you desire or that the engine can rev up to (6,000 rpm+). In stock form "almost all 700R4's transmissions will shift to the next gear anyways, especially on the 1-2 WOT shift.
Old Oct 24, 2001 | 02:39 PM
smoove1's Avatar
So it's okay to shift an auto like a stick? That is, it is okay start in "1" and shift up the console until you get to "D" or "OD"??
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
