Can I NOT resurface my flywheel?
Old Oct 22, 2001 | 04:00 PM
Mike89GTA's Avatar
Ok, I had a stock replacement clutch in and it lasted like 1000 miles before I dumped the clutch and now it barely grabs. I took the tranny out and the flywheel doesn't look that bad. I just got a used centerforce DF, can I just slap it on? Thing is it could take another week b4 I can find another flywheel (already resurfaced mine 4 times). I heard you can use some steel wool on the flywheel, is this true?
Old Oct 22, 2001 | 05:15 PM
87RS402's Avatar
As long as it still looks good: No heat checks or suspicious marks/discolorations, you can go ahead and just put it all back up without resurfacing it. With only 1000 miles on it I doubt you'll have any problems.
Old Oct 22, 2001 | 05:24 PM
zslug's Avatar
If there's any glaze on the flywheel and/or pressure plate, a little steel wool won't hurt.
Zslug
May the road rise to meet your treads...
'84Z, 5sp, stock 305, Edelbrock intake, GTA wheels
Old Oct 25, 2001 | 07:19 AM
arthur's Avatar
What you can use is the 3M emery grinding wheels for air grinders. The kind that do not remove metal. I forget exactly what they are called, but would make really short work.
Bubbajones_ya
Jul 6, 2024 08:32 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
