700R4 Questions
Old Oct 24, 2001 | 08:14 PM
JOHN/88IROCZ's Avatar
700R4 Questions
what would cause foamy trans fluid and how can i fix it. after i drive about 30 miles or so and then check the trans fluid it has alot of air bubbles or foam in it.
Old Oct 24, 2001 | 10:27 PM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
you probabally need to get your transmission flushed, to get rid of all the air bubbles.
Old Oct 25, 2001 | 04:18 AM
transfixleo's Avatar
Fluid and filter wouldn't hurt, just make sure that it isn't overfull or overheating.
Old Oct 25, 2001 | 08:07 AM
Nordbert's Avatar
If your fluid has bubbles and is at the
proper level on the dipstick, you might have
a dipstick that is too short. Filling to the full mark would actually be overfilled. If
your parts aren't original to the car, this
could the cause.
camaro11j
Sep 19, 2018 08:49 AM
redmaroz
Aug 16, 2015 11:40 PM
djmarch
Aug 11, 2015 10:22 AM
Leggman1
Aug 6, 2015 04:15 AM
