89 T-5 in place of a 91
Old Oct 24, 2001 | 05:11 PM
Killer-Z's Avatar
I have a 91z that has a t-5 that took an "s" on me. I am aware that I have an electronic speedo. I can get a deal on an 89(no electronic speedo). Is there any way to convert the 89 to what I need? Thanks guys Derrick
Old Oct 24, 2001 | 09:21 PM
Killer-Z's Avatar
Please!!
Old Oct 24, 2001 | 10:36 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Take out your VSS and put it in the other trans. One 10mm head bolt on each trans; 2 min. tops.
ICON Motorsports
Old Oct 25, 2001 | 07:57 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
<font face="Verdana, Arial" size="2">Originally posted by RB83L69:
</font>
Assumes the dirve gear is the same for each tranny. Look in there and check if they are the same color. Otherwise they will need to be swapped. All your 90 stuff can be swapped onto the 89. Good luck, Lon.
Old Oct 25, 2001 | 06:19 PM
Killer-Z's Avatar
<font face="Verdana, Arial" size="2">Originally posted by lonsal:
Assumes the dirve gear is the same for each tranny. Look in there and check if they are the same color. Otherwise they will need to be swapped. All your 90 stuff can be swapped onto the 89. Good luck, Lon.</font>
Thanks guys
Linson
Oct 24, 2025 02:00 PM
ZEEYAA
Apr 16, 2023 08:29 PM
Pac J
May 17, 2020 10:44 AM
RS Reaper
Oct 17, 2018 07:52 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
