Tranny Problem
Old Jul 13, 2009 | 02:44 AM
codyscamaroz28's Avatar
Car: 1982 Z28, 1991 RS
Engine: 350 Carbed, 305 TBI
Transmission: 700r4, t5
Axle/Gears: 3.23s posi Limited Slip, 3.08 posi
Tranny Problem
ok well i have a turbo 350. it goes in all the gears fine except i cant pull out in drive. When i put it in drive it acts like its in N or sumthing?So i have to put it in 1st gear go a little bit and then put it in drive and it works fine. So what do you thinks the problem?
Old Jul 15, 2009 | 01:24 AM
ed o's Avatar
Car: 64chevelle/smokey trans am
Engine: 350 p600 pro charger/350
Transmission: 350/700r4
Axle/Gears: 3.36
Re: Tranny Problem
either the forward or low/reverse clutches. burnt up. Probably the l/r's as they use square seals and normally go bad first.
greenyone
Sep 2, 2015 03:39 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
spaigo
Aug 21, 2015 07:46 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
