which is stronger t5 or t56?
Old Oct 23, 2001 | 11:22 AM
92Camaro305TBI's Avatar
Seems like the t5 .. Just wanted to make sure
Old Oct 23, 2001 | 12:10 PM
Brian Shaughnessy's Avatar
Car: '89 Formula
Engine: 355 TPI
Axle/Gears: 3.70 9 bolt.
If that was the case then why would we always be talking about how to swap T-56's into our cars?
Non-WC T-5 = about 250 ft/lbs torque.
WC T-5 = 300 ft lbs.
93 T-56 = 350 or 400 (depends on gearset).
94-97 T-56 = 450 ft lbs.
Tremec 3550/TKO T-5's are rated for somewhere between 400-500 ft lbs.
'89 Formula - Thunderchicken - 355 Vette L98/T-56/3.70 9-bolt/black/t-tops - the fun car!
'90 GTA - The GTA - 5.0 LB9/TH700/3.27 9-bolt/black/t-tops/tan leather - the cruiser.
Old Oct 24, 2001 | 05:49 PM
cort351w's Avatar
The 305 tpi with dual cats makes 300 lb*ft of torque stock. Does that mean that if I make any mods, I may end up with a broken tranny?
Old Oct 24, 2001 | 09:12 PM
skipsZ28's Avatar
Car: 85 Iroc
Engine: 385"
I've heard that torque ratings for a transmisson is taken from the maximum torque that can be applied to the transmission over a 24 hour period.
Using a motor spec'd at more torque than the transmisson is rated at doesn't mean that it will break. Their is lots of guys in the 12's with non-world class t-5's.
Old Oct 25, 2001 | 10:14 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
The T56 is way stronger than the T5.I'm not easy on transmissions, mind you,but my WCT5
had to be rebuilt at about 60k miles,mainly because I used to bang second gear a lot.Eventually,it wouldn't stay in second gear anymore.On top of the standard rebuild parts (bearings,syncros)it needed one shift fork,two gears and another input bearing retainer (the third).
Back then all I had in the car was the stock,170 HP TBI 305.Now that I have a 300HP 350 in the car, I'm planning on replacing it with a Tremec TKO early next year.
I woudn't waste much time or money on a T5,unless you never plan on popping the clutch or banging gears.
Any trans can be destroyed from abuse,just don't expect a T5 to take much before going away.
-Rich-
Old Oct 25, 2001 | 07:31 PM
Mark W. Winning's Avatar
Yeah, my T-5 was too strongs, so I swapped in a T-56. LOL. Just kidding, the T-5 is a throw away transmission. Run it hard and you may have to throw it away!
1992 Pontiac Firebird 350/Six Speed
1987 Toyota Pickup 383/500+ HP
Steven6282
Jun 3, 2011 10:21 AM
84z .....
Apr 14, 2010 12:30 AM
silverstreakII
Jul 2, 2001 05:56 PM
drain89
Jun 3, 2001 06:29 PM
