t5 build up or t56
Car: Blue 84 z28/Cyber 2010ss/rs
Engine: Dart headed, 12:1 355- 510/530 cam
Transmission: TKO 600 Lakewood Bell
Axle/Gears: Richmond 410 Spooled
t5 build up or t56
is it worth the money to get my t5 redone (because the syicro is F**T) or should i keep trying to find a t56,
i know the t56 is rated better in the torque department but its been hard for me to find one,, so is it possible to build a t5 up stronger??? or is it a waste of money.
thanks Sean
thanks Sean
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
Re: t5 build up or t56
I would repair the T5 and drive it nicely til you can get a T56. Just remember a T56 is also in need of some newer upgraded parts aswell and they are much more expensive to repair!
Cannot tell you the exact number of T5s i went through in my 3rd gens(A LOT) had $$$$ in a few that worked well for a while but when you lay the TQ down the T5 begins to show its limits...
I have been running my T56 96Z for 7 years and have had it gone through 2 times now.
thanks,,
im aware of the changes involved and ready for it . just cant find i good trans anywhere near me..SUCKS
Look around for a high mileage T-56 from an LT1 car, preferably the 94-97's because of the steeper overdrive ratio, and just have it rebuilt by Tick Performance. That's exactly what I'll be doing when I get my hands on a T-56.
"Recommended for all applications greater than 600ft/lbs of torque (rear wheel) - our level three rebuild is for the most EXTREME setups around! If you make BIG power, drive very aggressively and like to race HARD, you need our Level Three EXTREME Viper T56 Rebuild. This package consists of everything in Level Two, plus:
http://www.tick-performance.com/tick...ackages/fbody/
- Bronze 5-6 & Reverse Fork Pads
- Our Custom Shortened Viper Mainshaft
- Upgraded output shaft bushing
- Upgraded seal
- Custom machined tailhousing
- 30 spline slip yoke
- Modified Speed Reluctor"
thank you for the info.
topteam54
Oct 6, 2015 12:21 AM
el_muerte
Sep 16, 2015 12:01 AM
mygta87
Sep 14, 2015 10:36 PM
