Need TH350 Rebuild for 600 HP...Where to go?
Old Jul 13, 2009 | 11:53 AM
BadaPwned's Avatar
Car: 1984 TA 15th Anniv. Addition
Engine: 355 SBC
Transmission: TH350
Axle/Gears: 4.56
Alright guys, second gear in my trans went out this weekend, time for a rebuild.
The TH350 is sitting behind a 450 HP SBC with a 150 shot of nitrous.
Im in the Metro-Detroit area, any suggestions on where I should take / send it to????
Thanks alot.
Old Jul 14, 2009 | 04:11 AM
Pro Built Automatics's Avatar
Re: Need TH350 Rebuild for 600 HP...Where to go?
Are you looking at building it yourself? or having it built? Dana
Old Jul 14, 2009 | 06:23 AM
BadaPwned's Avatar
Engine: 355 SBC
Transmission: TH350
Axle/Gears: 4.56
Looking at having it built.
Old Jul 15, 2009 | 01:10 AM
ed o's Avatar
Car: 64chevelle/smokey trans am
Engine: 350 p600 pro charger/350
Transmission: 350/700r4
Axle/Gears: 3.36
that trans should get a thick center support, wide roller sprag, upgraded third gear drum with a sprag, not a cam style, a heavy shift kit, and good clutches/steels kit. I'd recommend a bolt in center support for that much motor, and build off a bearing style core for the most torque transfer. I build these locally, sorry. p.m. me and i'll send photos of what I would recommend during your build. I run a supercharged chevelle with a th350 for over 9 years with these upgrades, never been touched, and always abused.
Old Jul 15, 2009 | 06:31 AM
BadaPwned's Avatar
Engine: 355 SBC
Transmission: TH350
Axle/Gears: 4.56
Thanks for the input. I found a guy local here. His name is Mike Ridings. He got recommended by another good mechanic on another forum. I should be dropping my trans off to him today. Ill let you guys know how it turns out.
Thanks for the extra info Ed. I may print off what you stated and show the guy. We will see, as limited information I know now, their could be very little wrong or a ton of things wrong with the trans so...
But ill update you guys when I get the trans back. Thanks again, really appreciate the advice.
Old May 3, 2012 | 02:15 PM
Lionel Newby's Avatar
Are you still building these turbo 350's. I just had the turbo 350 got out in my 1983 MC ss with a 383 stroker 460HP/460TQ
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
hartsmike
Oct 2, 2015 07:11 AM
Derrick86
Oct 1, 2015 05:12 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
3.8TransAM
Sep 27, 2015 08:37 PM
