posi...which one....humm...
Old Jul 13, 2009 | 09:36 PM
TDwatts's Avatar
I have a 10 Bolt rearend in my z28... no posi.. id like to change that. I was kinda thinking just buy an I-roc rearend to get the posi and the rear disc breaks.. but i wouldn't mind just grabbing a posi.
anyone have and idea where to get one?? and which one?
Old Jul 14, 2009 | 06:11 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: posi...which one....humm...
I don't know where to find a "posi", but limited slips were available in a lot of 3rd & 4th gen rear axle assemblies. Check for RPO G80 which is the Limited slip code.
Old Jul 14, 2009 | 06:43 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Check the following link, which may provide some ideas:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Jul 14, 2009 | 08:02 AM
ian1320's Avatar
Car: 88 IROC-Z and 86 IROC-Z
Engine: TPI 305 and E85/Nitrous 383
Transmission: 700R4 and T56
Axle/Gears: 3:27 and TBA
just food for thought, not all IROC's had limited slip and disk brakes. My 85 Iroc is a one wheel wonder with drums
But i did pick up an 89 IROC rear with limited slip and disks, its the 9 bolt borg warner rear with aluminum calipers. From what i have read on this site its about the strongest rear you can put in the car that is a direct swap. 4th gen axles swap in but are a bit longer and require different wheels with a deeper offset.
Old Jul 14, 2009 | 09:10 AM
big gear head's Avatar
The Eaton Posi is the best all around limited slip differential for GM cars in my opinion. They last a very long time, they are rebuildable and can be tuned to fit your needs.
Old Jul 14, 2009 | 12:47 PM
ian1320's Avatar
i believe the 9 bolt borg warner rears also have 28 spline axles, the same axles as a 4th gen. They are stronger than the 26 spline 10 bolt axles.
I thought i read that on here somewhere but i cant find the particular post, can anyone verify?
