T5 swap questions :)
Old Oct 29, 2001 | 12:26 AM
crucial's Avatar
I just want to ask a question for people that swapped from an auto to a T5.
So far I bought a Zoom clutch from CSK auto with a lifetime warranty. As far as the pilot bushing that goes in the crank, they only had the solid bushing not a needle bearing. Will the bushing be fine for now ?
Also, I was wondering what I can use for a boot to go over the hole I'm gonna cut in the tranny tunnel for the shifter. Do any of the off the shelf boots work ? What about the boot for the shifter itself ? The plate I got has one on it but it's cracked and stiff and it's starting to tear in a few places. Any suggestions on what I can use for that ? Thanx in advance.
1991 Z28 5.7 TPI
ZZ4 heads, ZZ4 cam, Harland Sharp roller rockers, Accel base, SLP siamesed runners, 52MM SLP Throttle Body, Hooker Headers, Flowmaster catback, MSD6A ignition, Home made ramair system, 2500 stall, bullet proof 700R4, aluminum driveshaft...
Soon to be installed. WC T5 !
Old Oct 29, 2001 | 07:16 AM
Ryan89IROC's Avatar
The solid bushings work fine. For both boots I would cruise the junkyards. You can buy the whole trim plate with boot for $90 from classic industries but if you can find one in a junkyard it'll be much cheaper.
Frozer!!!
Jan 19, 2024 04:55 PM
theurge
Aug 21, 2015 12:46 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
