would a buick TH400 fit????
Old Oct 26, 2001 | 11:50 AM
92 RSS's Avatar
Car: 1992 Camaro RS
Engine: 5.7
n/m
My Website
92 RS, 350, Street & Performance MPFI, TFS heads, Stock crank and rods, Fordged flat tops,
Crane Rollers,
MSD Digital 6 Plus, 22lb injectors,
ZZ3 cam, Edelbrock Headers 1 5/8, 3" Exhaust,
Hi Flow 3" Cat, stock T-5,
stock rear 3.08, koni yellow adjustable front, twin turbo glass hood, T-tops, Auto Meter Ultra Lite Series 2 5/8 gauges, Teal Green
Est. 365Hp 420+Lbs.
Old Oct 26, 2001 | 01:01 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
You'll need an adapter plate for the BOP pattern, a cross member kit for the T400 and a drive shaft, but yes, it will fit. You would be better off finding a chevy pattern though and unless you are making big power, stick with a T350 or something.
Miles
88 427 Camaro
12.18 @ 113mph 1.75 60ft
Currently installing 3.73's into my 9 bolt (YES, it is a 9 bolt & YES they are 3.73's, not 3.70. I currently have 4.10 gear sets and new series 3 carriers in stock for 9 bolts )
www.koolmeister.com
Old Oct 26, 2001 | 01:12 PM
91 Bandit II's Avatar
Ive used that adapter plate before with a BOP tranny and a chevy engine. It was a big headache putting small spacers between the torque converter and the flywheel. The other problem you will run into is the flywheel weight will probably rub on the adapter plate. Mine did. I would recomend finding a tranny with the chevy bolt pattern or the universal bolt pattern
Old Oct 27, 2001 | 01:28 AM
SoCo80p's Avatar
i put the adapter chevy engine to bop trans from TCI and it fit and works great, mabey you put it in wrong?
Old Oct 29, 2001 | 04:26 PM
i had a one piece rear main chevy 350 and the weight on the flywheel faced toward the block. no i didnt put it in wrong... I dont know how it could possibly be put on wrong
New2Chevy
Sep 28, 2015 12:35 AM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
Nick McCardle
Sep 10, 2015 08:36 PM
BOOT77
Sep 5, 2015 03:55 PM
