which transmission to get?
Old Jul 16, 2009 | 12:52 PM
snowboardgod869's Avatar
Car: 1991 RS Camaro
Axle/Gears: 9 bolt 3.27
right now i have a 1991 rs camaro with a 305 with a 9 bolt Borg Warner with 3.27 posi rear end and an automatic transmission i want to get ride of the auto i plan on putting an engine in when i get some more money with some where around 400 hp and change the gears in the rear end to 3.73 what kind of transmission should i get t5 t56 or any other kind of transmission i know summit has a tremic 5 speed that can hold up to some beating and first gear is a 3.27 which should fly i think any of the t5 have just over a 2.0 first gear not exactly sure but the tremic is a little over 2 grand but i dont rly have the money for that so whats the best transmission for the price to convert my auto to manual
Old Jul 16, 2009 | 01:47 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: which transmission to get?
T5: 2.95:1 first. T56 retrofit version: 2.97:1 first. T56, '93, 2.73:1 axle = 3.36:1 first. T56, '93, 3.23:1 axle = 2.97:1 first. T56, '94-'02, 3.42:1 axle = 2.66:1 first. Tremec TKO500: 3.27:1 first. TKO600: 2.87:1 first. The TKO600 is as strong as the T56, and is lighter, and but ends up costing just as much as the T56 by the time the installation is complete. You might be able to find a good deal on a used TKO or older Tremec TR3550 from a Mustang guy, then use the McLeod modular bellhousing to install it. It's alot like a TKO500.
Old Jul 16, 2009 | 03:58 PM
Car: 1991 RS Camaro
T56, '93, 2.73:1 axle = 3.36:1 first so this t56 has the highest first gear ratio at 3.36:1 for first gear right?
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
TX-SleeperC5
Sep 24, 2015 03:13 PM
Youngs92
Sep 23, 2015 11:29 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
